Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
14MZ RF Module not connected
Old 01-03-2011 | 10:05 PM
Default 14MZ RF Module not connected
Hi,
I have an odd problem with my 14MZ. On the first boot up of the day i get the message "RF module is not attached turn off the power switch attach the RF module" If i turn off the radio and turn it on again everything is fine no problems, for the rest of my flying session. I have even been careful not to bump, wiggle the RF module. It all appears to be connected properly, pins look good etc. I have updated the software in case there was a bug, unfortunately to no avail.
Any ideas?
Many thanks for your help
Regards
Chris
Old 01-04-2011 | 11:58 AM
Bax
Default RE: 14MZ RF Module not connected
It sounds like you have something physically wrong. Try removing and reseating the module. Otherwise, you may have something physically wrong...a bad pin, a bad solder joint, a bad connector inside the module, and so forth.
Old 01-04-2011 | 02:08 PM
Hi,
I have tried before to reset the module. No good.
If it were a bad joint i would have thought the fault would be repeatable. But the fault only happens on the first start up of the day.
Thanks for your thoughts, as it gives me something to look at
Regards
Chris
