Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
4EXA Throttle level Problem
Old 01-23-2011 | 08:15 AM
Default 4EXA Throttle level Problem
Hello:
i purchased Futaba Radio 4EXA and set everything up right on an EDF jet, am facing a problem when i move the throttle stick up, the motor doesn't spin unless i reach half way on the throttle stick and i have no idea why this is happening, can anyone help?
i use turnigy ESC 30A Plush
Old 01-23-2011 | 02:04 PM
Default RE: 4EXA Throttle level Problem
Heeeeeeeeeeeeeelp!!!
Old 01-26-2011 | 12:52 PM
Bax
Please be aware that your first post was at 10:15 AM on a Saturday. We don't usually see these posts until Monday, at the earliest. It does sometimes take a few days for us to get to posts in the support forum, so your second post six hours later is not in line.
As far as your throttle difficulties are concerned, you may need to check the endpoints and travel settings in your transmitter. If they are OK, then your speed control is the culprit. Many times, a motor will not start to move until the speed control, itself, is at a rather high setting.
