Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
servo hum
Old 04-19-2011 | 07:07 AM
Default servo hum
Hi all, I installed several S3010 servos in a plane and when the power is turned on they all hum quite noticalbly.There is no binding or anything like that. Any help/comments will be appreciated.
Old 04-21-2011 | 06:45 AM
Default RE: servo hum
It looks as though this was cross posted in the main forum.
If you suspect the hum is excessive, I would check the control rods and make sure there is no binding. If there is no binding, you are welcome to send these in to be checked in our service center.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 04-21-2011 | 07:00 AM
I have 12 of them in my plane and they all hum.There is no binding. Will a 2.4 radio make a difference from an fm radio?
Old 04-21-2011 | 07:17 AM
No, that should not make a difference at all.
There is another problem somewhere, I would check your battery or if using an electic motor, are you using a filter, as motor noise could a problem also.
Sincerely,
Krysta
[email protected]
Old 04-21-2011 | 11:04 AM
I am using [2] recievers with [2] 4v batt packs
