Trim mix T9ZHP
![](/forum/images/badges/trading_plus_member.png)
How can I use the trim from the elevator to bolth sides of the elevator when they are mixed usning in the elevator as master and the Flap as slave. My radio is Futaba T9ZHP[:@]
If you are using Ailevator for your dual elevator servos, the trim should trim both servos when you use it. Even though you have a mix with your Elevators to Flaps, the trim will allow both dual elevator servos to trim if used in the Ailevator menu.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
