Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
4 Aileron servos
Old 09-01-2011 | 07:22 PM
Timber29's Avatar
Default 4 Aileron servos
Hi, I'm building a Waco Biplane it has four aileron servos. I have a 10CG radio with a 14 Chanel receiver I have two servos on chanels 1and 7 no problem there. I've been trying to get the other two servos useing the program mix useing 1 and 7 as the master and 6 and 8 as the slave. But I can't get it to work, will I be able to do it with out useing a Y harness. Thank you
Old 09-03-2011 | 09:29 AM
Timber29's Avatar
Default RE: 4 Aileron servos
Hi I got it working, found it in FAQ I didn't thing that would be in there. But anyway here is if somebody does a search and comes across this post.
http://www.futaba-rc.com/faq/faq-10c-2_4ghz-q682.html
Old 09-06-2011 | 06:21 AM
Bax
We're glad to hear you found your answer.
Old 01-05-2012 | 07:14 AM
Would this also work with the 8FG in multi2 with a 14 ch Rx?
FB
