12FG
My Feedback: (18)
I have a flap to elevator mix and have assigned one of the knobs for fine tuning. I realize this is fine tuning but the amount of movement from +100 to -100 is very little. Is there any way to increase the range of movement? Thanks.
Marty
Marty
The fine tuning adjustment affects the mix based upon the amount of mixing you've set up in your curve. If the slave channel only moves 20% of the movement of the master channel, then the fine tuning can only move that 20% if you have it set up to 100%. The fine tuning cannot add movement to the mix. It can only reduce it. If you want more tuning range, then you'll need to set the Rate A and Rate B to a higher value. Then the fine tuning adjustment can reduce the amount of mix from there.
My Feedback: (18)
Thanks for the info.
Instead I tried setting up conditions which I though would be easy but I'm having trouble. I figured I would just have a "landing" condition activated when I switch to landing flaps position. This way I could just use the elevator trim to fine tune the flap-elevator mix but I can't get it to work independently. when in the landing condition, I adjust the trim but when I switch to normal flight condition, the trim doesn't go back to normal or "flight" condition. I've changed the elevator channels to singe instead of group but there is no change. I know I'm probably just missing something simple but any help would be appreciated. Thanks.
Marty
Marty
