Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Offset question
Old 11-28-2011 | 06:25 AM
My Feedback: (9)
Default Offset question
I am experimenting with the programming in my 8FGS and am working on the Throttle cut and Idle down menus. Throttle cut is set by a percentage but idle down is "measured" by offset. I was wondering if you could explain the term "offset" to me.
Sam
Old 11-29-2011 | 01:32 PM
Bax
Default RE: Offset question
When you use Throttle Cut, you are setting an absolute position as regards to the amount of total throw of the function. With Idle Down, you are moving from the current position, so you are offsetting from the current position.
Old 11-29-2011 | 07:40 PM
My Feedback: (9)
I'm still not sure I get it, although by looking at the Servo display and using some loose servos I can see the results when I adjust it. These 8FGS's are great radios. I had a 10 CAG and sold it to buy a second 8FGS (one heli and one air). Now that I've made the plunge I'm determined to learn these suckers!
Thanks Bax.
Sam
