Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
t6xas problem
Old 03-19-2012 | 02:43 PM
Default t6xas problem
My 6 xas has been working perfect for years and all of a sudden channels two and three switched. It was out of nowhere. I had it on setting up the throws and mixes on a new plane, everything was perfect, ran upstairs and left the radio on and when I came back there was something on the screen that I don't remember ever seeing during normal setup , I don't remember what it said because I didn't think much of it. After that the problem started . I have reset the controller and made sure all mixes were off but nothing changes it. Any help would be appriciated!
Old 03-22-2012 | 12:07 PM
Bax
Default RE: t6xas problem
It's possible you accidentally switched the transmitter from Mode II to Mode I. To change the stick mode, hold down the two "MODE" buttons on the transmitter while you turn it on. You'll then see a display that has "STCK" plus a number. Likely, that number is "1" at this time. Change it to "2", and then turn off the transmitter. Your now back to your regular setup.
This is described on page 5 of the transmitter's instruction manual.
Old 03-23-2012 | 08:49 PM
Yup. I figured that out right before I got on here. Don't know how that happened
Thanks. Bax. I was also wondering if there is any way I can get a replacement. Backside of the radio? Not the battery Cover bt the whole back plastic?
