Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Vector thrust problem
Old 06-03-2012 | 10:31 AM
Default Vector thrust problem
Hi
I have a problem with setting up my Sebart Mig29.
I have programmed as the instructions describe with the Vectored Thrust channels on Aux1 and Aux2.
For some reason I can only get Aux 1 to work. I have checked the instructions and double checked but can't see what I may have done wrong.
I am using a Futaba9c with a Spektrum 8 channel module. I haven't had any issues before and I have checked the servo and it works fine.
I know it's a bit of a lame question but any help would be great.
Shaun
Old 06-05-2012 | 11:52 AM
Bax
Default RE: Vector thrust problem
We'd like to help you, but you didn't state how the aux channels are controlled. Do you use a mixer? If so, you need to have one mixer for each aux channel, so if you're mixing elevators to the vectored thrust, you need a mixer of elevator->aux1 and a mixer of elevator->aux2. Can't do it with just one mixer.
Old 06-05-2012 | 12:58 PM
Hi Bill
thanks for this
Yeah I am using a mix to get the Vector thrusts to work.
Vector 1 is AUX1 Vector 2 is AUX2.
I can get Vector 1 to work with the rudder, ailerons and elevator, But Vector 2 only works
with the rudder as it is coupled into the 2 rudder servos and into the rudder socket on the reciever.
I have copied word for word the instructions in the models manual but Vector 2 just doesnt work
for the elevator or the ailerons. I think it may not be assigned correctly but I have tried it on Aux3
on the reciever and it still doesnt work.
Like I say I have checked the servo independantly and it works fine but wont work as a Aux channel.
I have attached a link for the Manual and the mixing instructions are towards the back.
Any help you can give me would be great.
Shaun
http://www.sebart.it/download/Mig29%...203D%20edf.pdf
Old 06-05-2012 | 01:00 PM
Sorry Bill
the link is a bad one
try this
Thanks Shaun
http://www.sebart.it/.../Mig29%203D%...%20MIG29%203D%
