Setting up Switchglo Pro to throttle
My Feedback: (21)
I have a 10CAP Tx. I would like to set up my Swtichglo Pro to come on at low throttle. Or say the last 5% or so to turn it on. I have played around with all the settings in the mix but to no avail. I have the switch as throttle. The mix is Ch3 master to Aux 1 or Chanel 7 slave on a 7 Ch Rx.
RE: Setting up Switchglo Pro to throttle
You'll need to use a curve mix, but you won't be able to use the "last 5%" of the master channel as the switch. It will be the last 1/4 or so. With the point mix, use Throttle as the master and the desired Aux channel as the slave. Set all of the points to one extreme, except for the last two at one end. Set those to turn on your glow driver. That way, the glow driver will only come on when you move the throttle stick below 1/4.
The 10CAP cannot have as fine a control as you want.
