SBD-1 Question
My Feedback: (38)
I just had an new SBD-1 go bad while setting up a new model. The servo quit working suddenly. I traced the problem to the SBD as the servo worked correctly etc. I thought maybe the channel programming was lost so I rechecked it with a SBC-1. It would only blink fast continually and would not allow me to program the SBD-1. I the programmed another new SBD-1 and all worked correctly. I will send the bad one in for warranty.
I am using the SBD-1's with a R7008SB receiver on high voltage (A123). Is high voltage a problem with an SBD-1?
I assumed that since the SBD-1's were made for receivers capable of high voltage, they would accept high voltage.
Please advise.
Thank you
Please advise.
Thank you
