Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9CAP SUPER Need help with flaps setup on slider "VR E"
Old 09-20-2014 | 02:49 PM
Unhappy 9CAP SUPER Need help with flaps setup on slider "VR E"
I am new to this radio even though it is old and this thing makes me feel like a box of rocks. I have a plane with two separate servos for the flaps. I know that ch6 is for flaps and when I pull the switch "E" it works for one servo plugged into ch6 in the receiver. I want to move Flaps from the switch "E" to work on on slider on right side of radio "VR E". My second servo is plugged into ch7. What do I need to do step by step, PLEASE, to set this up.
Thank you
Old 09-22-2014 | 07:02 AM
Bax
In the menu, there is the AUX-CH function. There, you can set which control activates which auxiliary channel. Just set the flap channels to the appropriate control slider.
Old 09-23-2014 | 07:38 AM
Thank you BAX. I was able to set ch5 to the slider VR "E" as you suggested and it worked fine for one flap only. How do I get the other flap/servo linked to this switch and how to set the amount. Please show step by step. Thanks again
Old 09-24-2014 | 06:22 AM
Bax
If the second flap is on a second auxiliary channel, just set that channel to VR-E as well.
Old 09-30-2014 | 10:43 AM
Call me a Dummy!. I had a servo plugged in backwards into the receiver. Once I changed this the flaps worked great. Thanks again for your help.
