Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Same plane on multiple model settings
Old 04-18-2015 | 05:29 AM
Default Same plane on multiple model settings
I have a 6EX Fasst system and I noticed that no matter which model I select in the programming, it acts as if model 1 is active. Should the receiver in the plane respond to all models or just model 1 setting?
TIA
Andrew
Old 04-20-2015 | 07:53 AM
Bax
When you link a receiver to your transmitter, it will work whenever it and the transmitter are turned on, regardless of the model selected in the transmitter. You always need to check to make sure you have the desired model selected in the transmitter.
Old 04-20-2015 | 10:11 AM
Aha, ok thanks. So these models are basically a saved set of configs, not different receivers.
If I have to planes with two different receivers turned on and the transmitter in range they would both respond to the signal from the transmitter?
Old 04-21-2015 | 06:05 AM
Bax
That is correct.
