Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Range check with Futaba TM-7 module
Old 07-22-2015 | 09:08 AM
Default Range check with Futaba TM-7 module
How do I do a range check with a Futaba 9C transmitter with a TM-7 module? Its been a long time since I did one and the manual is missing.
Thanks in advance,
Bob
Old 07-22-2015 | 11:30 AM
Bax
Here's a link to the manual:
http://manuals.hobbico.com/fut/tm7-manual.pdf
Basically, you link the receiver to the transmitter, then, while everything's turned on, you press the "F/S Link" button and the module will power down for range checking. The red light should blink to indicate this. After about 90 seconds, normal power will resume.
Old 07-22-2015 | 03:35 PM
Thank you!
