Rx Won't Bind
Sorry if this topic has been covered before, but I found nothing on it in a search.
My new Rx will not bind to my transmitter. Following the procedure with the Tx on (w/green light on the back). I turn on the Rx and push the switch to get the flashing red LED. The light continues to flash red without converting to solid green. I have not done a binding before, so I don't know how long it should take. I have waited it out past 30 minutes, but no change.
My transmitter is a T6EX that I know is working as it communicates correctly with the Rx that came with it. The Rx is a new R2006GS. Am I trying to bind incompatible Tx and Rx?
Thanks in advance,
Bedford
Thanks in advance,
Bedford
The R6002GS is not compatible with the 6EX transmitter because it uses the S-FHSS protocol and the transmitter uses the FASST protocol.
We deleted the other posts because this is a forum for people to get help from the Futaba Support staff. Others are not permitted to reply to questions. This is also not a discussion forum.
