Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
18SZA Programming
Old 02-22-2016 | 09:34 AM
Default 18SZA Programming
I just purchased the 18SZA to replace my 14SGA. While manually programming the 18SZA from my 14SGA I noticed 2 significant differences that I need help with.
1) On the 14sga I have the "Motor" function programmed with switch sc up for on, then switch sh for start for safety reasons. I cant find where to program the start switch in the 18sza's Motor function.
2) I cant find where I set the voice for the timer readouts.
Thanks.
Old 02-23-2016 | 07:07 AM
Bax
You would set a switch to operate a function in the Function section of the Linkage Menu.
In checking the instructions, there are no voice alerts available for the timer. Voice alerts are available for telemetry functions, and then only through the earphones.
Old 02-23-2016 | 08:13 AM
Thanks for the quick reply. The 'Motor' function in my 14sg has a main switch to enable the motor but there is also one called start switch on the Motor function setup screen. I don't see the start sw in the motor function of the 18sz.
Are there any plans via firmware update to get the timer warnings via voice on the speaker. I really liked that feature on the 14sg. I hooked up an external speaker to my 14sg.
on the 18sz I did get the telemetry audio through the speaker. Maybe the audio for telemetry goes through the speaker and alerts from telemetry go through headphones only but that would be rather silly???
