Telemetry data
Hello,
I have a Futaba 18mz. I wanted to know when the min max telemetry data gets reset. Fido I need to do it for each sensor or does it ger reset every time you restart the receiver (and the telemetry sensors).
And what does the telemetry data reset button do ?
thank you
thank you
When you turn on the transmitter, then the max/min readings for that particular session are reset. However, the max/min/warnings are not reset unless you go into the transmitter to reset them.
The telemetry reset will reset all of the max/min settings and warning settings in your model memory without affecting any other model settings.
