Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Programming 7c 2.4 for warbird with 2 elevator servos
Old 06-25-2016 | 08:16 PM
Default Programming 7c 2.4 for warbird with 2 elevator servos
I am building a mustang that has 2 elevator servos and am thinking of using a 7c 2.4 radio. I understand that with 2 elevator servos you plug one into channel 2 and the other into channel 5, and use the ailevator function to control them both. I have two questions:
1. which channel do I use for the retracts which usually would be on channel 5, and how do I use the switch that usually operates them on channel 5 to operate the retracts. I believe that I would use channel 7 since that is unassigned so far.
2. how do I power the receiver? I believe that I should use a y connector on one of the channels and plug the receiver battery into one side of the y - would I use channel 7 for this? or 6? or another method?
thank you for your help.
Ed mullen
Old 06-26-2016 | 06:20 AM
All Day Dan's Avatar
Ed, which receiver are you using? Dan.
Old 06-27-2016 | 03:59 AM
the R 617fs receiver that came with the 7c.
channels used for
1ailerons
2 elevator 1
3 throttle
4 rudder
5 elevator 2
6 flaps
7 retracts and battery (I think)
Old 06-27-2016 | 07:15 AM
Bax
Any slot in the receiver can be used for power. If you're using 7 servos, just "Y" the battery into any slot.
You can change the control that activates channels 5 or 7. Page 28 of the manual details how you can do that. It's in the PARA section of the menu structure.
Old 06-27-2016 | 09:13 AM
thank you
ed mullen
