Safe operating limits
Hi Bax
Was wondering what you might think of operating on S Bus through SBD 1's JR 8711 servos. I will be setting up a 40% aerobatic type airplane (flying IMAC like maneuvers) that may have a total of 10 that would be powered by 2S Li Fe's 5800 mah, that would have a draw of about 400 oz/ servo. And also two more standard servos of 100 oz or less. Would this be too much for an S bus system?
Alan
Alan
If you power everything through the receiver pins, then you will need to insure the wiring can handle the load. You will need to use heavy-duty wires and connectors throughout. If you are providing power out at the servos, you won't need as heavy-gauge wire because your leads won't be as long. You can purchase heavy-duty connectors. Futaba makes them:
FUTM4135 AEC16 H/D DUAL SERVO EXT 6" J US$12.99
FUTM4140 AEC14 H/D SERVO EXT 8" J US$7.99
FUTM4145 AEC15 H/D SERVO EXT 16" J US$8.99
FUTM4147 AEC17 H/D SERVO EXT 20" J US$8.99
FUTM4148 AEC18 H/D SERVO EXT 40" J US$11.99
FUTM4180 AEC20 HD SRVO EXT W/FLTR 220MM US$19.99
FUTM4385 SWH14 H/D SWITCH W/CHARGE CORD US$21.99
FUTM4391 HEAVY DUTY ELECT SWITCH DEANS US$49.99
These parts can be ordered through any hobby retailer who sells Futaba systems and accessories.
