Throttle position warning
I recently purchased a TJ6. When I went to do some programming today, the Throttle position warning started. I moved the stick back with no response. The warning continues until I turn the unit off. What have I done wrong and how do I correct it?
I somehow, managed to switch into another Stick Mode since the Throttle/Rudder stick now is controlled by the stick on the right! How that happened is a mystery? Today's mission is to read the manual and get back to Mode 2! Thanks for your response and help! Doc
