Super 7 question
My Feedback: (12)
CA
Super 7 question
I just aquired a super seven and was wondering if it is possible to use the three way switch as a channel. I will be running one of the old Sophia jet engines and the instructions call for two channels, one for throttle and one for startup/auto shutdown/ emergency shutdown. The latter is supposed to be operated by a three way switch. It is possible to use a rotor, but since the Super 7 has a three way switch I though I would ask.
Nathan
Nathan
RE: Super 7 question
Hi Nathan,
Unfortunatley, the 7U does not have the switch assignability options that some of our newer radios offer. The 3-way switch on this radio is used for channel 2-6 or 6-2 activation.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
