Field Force 9
Just a quick question that I hope some one can help me with.
I have a Field Force 9 for use with my airplanes, what I want to know is....
I've just bought a boat and some cars can I get a module to change my transmitter into a 40Mhz unit for use with these boats and cars?
Also, how do I set up channel 7 and not channel 6 to be the second aerolon?
Thank you.
Thank you.
Hi FI_Flashman,
Yes, you would just need to purchase a new module and receiver on the ground frequency allowed in your country.
To set up dual ailerons with the second on channel 7, you will only need to activate Ail Differential in place of Flaperons.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
