Servo Reversing
Hi Guy's
I have a pair of Futaba s9402 servo's which I plan to use for flaps, I need to revarse 1 of the servo's.
Can you tell me how to go about this please.
Thanks in advance
TONY
Thanks in advance
TONY
Hi Tony,
Most current radios have a servo reversing selection built in, either as a switch or in their programming. This is where you should start, if you do not have a radio with this function, or you are using the servos with a Y harness, you can either purchase an inline servo reverser or physically change the positioning of the servo itself.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
Thanks Krista, but I need to reverse the the servo within itself as I can not alter the location of the servo and I am not confident with a servo reverser in line.
Thanks again
Tony
Thanks again
Tony
