8U tailerons & flaperons?
Building an SU-27 (twin turbine) with flaperons and tailerons the flaperons would be slaved to the tailerons, I think, since I'm told the tailerons provide the primary roll control. I have flaperons on my Pilatus Porter with the standard ch 1/6, dial setup. Is this doable with the 8U?
Hi wsmalley,
If you already have Flaperons set up, you should be able to set Tailerons up in conjunction with this by a series of Pmixes. This would require at least 3 available Pmixes.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
