Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Flap knob changing
Old 07-09-2002 | 02:47 PM
Default Flap knob changing
Mrs. Cross,
I recently setup my 8UAFS for my P-40 that has dual aileron servos and a single flap servo. I used the FAQ (http://www.futaba-rc.com/faq/faq-8u-q177.html) to do this and it works well. But I was wanting to change the flap knob to the left (channel 6) knob instead of the right knob (Channel 7 I think).
But my ailerons are plugged into channels 1 and 6. I know the 8U isn't fully switch assignable but I was wondering if I could do this assignment?
Thanks.
Old 07-09-2002 | 02:53 PM
Norris,
Sorry, not easily, no. Do you need flaperon on your ailerons? could you use aileron differential instead, moving the second servo to ch 7?
Old 07-09-2002 | 03:08 PM
Actually I don't use flaperons at all. But I had problems getting the ailerons working correctly with it plugged into channel 7 (hence why I found and followed the FAQ to get everything working)..
I'll just stick with it now and once I figure out how much flap I want, assign that amount to a switch.
Only reason I ask is I like to be able to have my switches/knobs that effect my right handed controls, on the left side of the transmitter. For example controls for flaps, retracts, etc.. , which effect elevator (right hand), I like on the left side. Controls that effect throttle (left side), I like on the right side (throttle cut).
Thanks.
Old 07-09-2002 | 03:44 PM
Norris,
No worries. If you'd like to try, just move your 2nd aileron servo to 7. make flaperon INH, and then make AIL DIFF active and set up any differential if you want any at all.
