Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
How do I setup mix for using flaps?
Old 07-11-2002 | 12:56 AM
RightThrust's Avatar
Default How do I setup mix for using flaps?
AM, how do I set up a mix to use flaps with flaperon's activated. I have the servos in 1 and 6 but can't seem to get the flaps with the left dial working, what's the easiest way, with a pmix or the airbrake function, if so, how do you do that?
-Kelly
Old 07-11-2002 | 11:41 AM
Kelly,
If all you want is for the flaperons to move as flaps on the ch 6 dial, simply turn on flaptrim, the feature that gives you flap action on that dial.
if you want the flaps to move on switch C you can use airbrake.
if you want the flaps to move anywhere else, simply do an OFST to FLP mix, set the desired percent, and set the desired switch. This moves the flaperons together as flaps the desired offset distance when taht switch is active.
Old 07-11-2002 | 06:41 PM
The main reason I want to have flaps is for the ELE->FLP mix for fun fly maneuvers, when but when I set that up it only moves channel 6, how can I get it to move 1 and 6?
I did setup 2 mix's which were AU1-AIL and AU1-FLP but there has to be an easier way.
-Kelly
Old 07-12-2002 | 01:59 AM
The elevator to flap mix, as a prebuilt mix, doesn't have a link function so you can't tell it to obey teh link feature and thus command the second servo.
simply use a regular mix, mix elevator to flap, and turn link on.
