Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
6XAS problem
Old 07-06-2004 | 09:56 AM
My Feedback: (20)
Default 6XAS problem
I have a Futaba 6XAS radio system channel 24.
My problem is when I switch between HI and LOW rates my
elevator moves up 1/16"-1/8" with the trims centered and no stick input.
It moves up when I switch to high rates then back down when I go to low rates.The only mix I have turned on is for the ailerons to be used on seperate channels.
tried hi/lo rates on 1 and/or 2 switches does the same thing.
Any help or advice is greatly appreciated.
Old 07-08-2004 | 04:25 PM
Bax
Default RE: 6XAS problem
If your trims and subtrims are centered, and you still have the problem, then your stick pots need to be calibrated. The affected transmitter needs to go into the service shop to have that done. Many times, model memories will wind up being deleted during the calibration process, so you may want to write down your settings before sending.
