Rotary Dial
NM
I have been using my 9c transmitter for about 6 weeks and to my suprise the rotary dial that is used to select models and other radio functions has came loose and fallen off. I am careful in the operation of this radio and it is transported in a protective case. I dont belive a transmitter of this caliber should have this problem. Could you please advise me on how to secure the knob to the dial shaft as the fit of the plastic knob on the shaft is very loose. And thank you for the answer to my battery port quedtion.
Thanks, wingsnh.
Thanks, wingsnh.
Hi wingsnh,
Please send this into us at the Service Center and this will be taken care of for you. The address and a printable "return for service" form can be found on our website at:
http://www.futaba-rc.com/service.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
