Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Air Brake switch assignment on 7-Cap
Old 08-26-2004 | 01:33 PM
KingSalomon's Avatar
Default Air Brake switch assignment on 7-Cap
Hi, Is there any way to assign the A. Brake function to a different switch? Right now it is assigned to "G", which is the 3-position switch. I am using this for triple rates, and 3-positions are not needed for the air-brake. I want to move the function to switch "D". Thanks!
-------Dan Fordice
Old 08-27-2004 | 10:40 AM
Default RE: Air Brake switch assignment on 7-Cap
Hi Dan,
The only way to do this on the 7C would be with a series of three Offset mixes. The first Offset to Elevator, then Offset to channel 6, the Offset to channel 1. As there is no "link" function in this radio you would use all available mixes to move this to another switch.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
