DIGITAL SERVO PROGRAMING
ID
CAN THE TRANSMITTER BE USED TO PROGRAM DIGITAL SERVOS OR DO I HAVE TO BUY A PROGRAMER? I AM USING A FUTABA T6X AND WOULD LIKE TO USE THE PCM MODE FOR MY 33% ULTIMATE. I HAVE NEVER USED DIGITAL SERVOS, BUT THIS AIRPLANE DESERVES THE BEST.COSTS ARE AN ISSUE HOWEVER.CAN YOU SUGGEST A GOOD DIGITAL SERVO FOR ELEVATOR, AILERON, RUDDER TO USE. I AM ALSO USING MS-10A ON ELEVATOR/AILERON.
THANKS
THANKS
Hi DOORGUY1,
There is no programming required for digital servos. And any digitals should be fine in conjunction with your MSA-10. Some recommended servos for your 33% Ultimate would be the S3050, S3151, and S9252. Also you may want to look through some of our digital servos on our website at:
http://www.futaba-rc.com/servos/futm0211.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
