Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
7C setup for Duel Elev Servos
Old 09-30-2004 | 01:03 AM
My Feedback: (36)
Default 7C setup for Duel Elev Servos
I have setup dual elevator servos before using a Futaba 8 ch radio. I wanted to setup dual elevator servos to work in conjuction with the alierons and then go back to standard elevator setup. Can this be done using the 7C
Old 10-11-2004 | 10:49 AM
Default RE: 7C setup for Duel Elev Servos
Hi WALKERS210-RCU,
You can do this with 2 Pmixes.
First do a Pmix with Aileron as Master and Elevator as slave. Select a switch for this to be on, and then make the rates +100% both ways.
Next do a second Pmix with Ailer as Master and your second Elevator channel as Slave. Again select the same switch in the same configuration as the first mix, and again have the rates at +100% both ways.
If you are using channel 5 as your second Elevator channel, you will want to make sure to go into the Parameter menu and Null out the channel 5 switch.
This will make your radio operate normally with the switch off, but your elevators will act in conjunction with your ailerons when the switch is active.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
