Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
using while charger is plugged in
Old 10-30-2004 | 09:09 PM
radcast2's Avatar
Default using while charger is plugged in
Hi I am using the Futaba 6EXA and want to know can I use it while the charger is plugged in?
Old 10-31-2004 | 02:22 PM
radcast2's Avatar
Default RE: using while charger is plugged in
I found out that when you plug the charger in it will charge but if you turn on the power the charger stops charging.....I cant believe it takes 10hrs to charger the battery.
