9 CAP programming Help.
ON, CANADA
I want to use flapperons on my Harrier 3D to make harriers more stable but I do not want them on all the time. I tied to use the airbrake function but I couldn't seem to get it to work. How do I go about this?
Thanks in advance.
Don
Thanks in advance.
Don
Hi Don,
As long as you have your ailerons in channels 1 and 6, Airbrake should work for you for this.
You must of course have flaperon Active, then go into Airbrake, make it active, and dial to zero (0) both Elevator and Ail2. Make sure that Ail1 and Flap are both set to +100%. If you want the dial to NOT affect your flaps you need to go into Aux Channel and make channel 6 Null instead of VR-A.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
