R319-DPS
Hi,
The R319 is my first 9-channel receiver. I assume I should plug my 6 volt power into the channel marked "9/B", but could not find this documented anywhere in instructions or on Futaba website. Thank you.
R. Buhrman
R. Buhrman
Use a Y-harness to plug the battery power lead and any servo lead into the receiver in any servo channel. Power can be applied in any of the slots in the receiver.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: rbuhrman
Hi,
R. Buhrman
Hi,
R. Buhrman
Over time, certain components go out of production. The receiver then needs to be redesigned with newer components that are available. There are no performance differences between the R309DPS and R319DPS receivers. They are slightly different in design because of the differences in components.
