7C and elevon problem
FL
Hello,
I just built a Diamond Dust (delta). I activated elevons mode on my 7c and everything works but...
For some reason I get much more "up" travel on my elevator then I do "down" elevator. I got all end point set to max. On elevon menu, I have ele set to 100%. I did notice if I take it down to 50%, both up and down travel is about the same but I want to travel I get when it is set to 100%.
Any ideas?
Mike
Any ideas?
Mike
Hi Mike,
You may want to undo your control linkages and reset your servo center to make sure that both servos are set up as perfectly as possible.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
