Use switch to change channels?
WA
Newb alert! hehe
I have a Futaba 7C. Is it possible to set up one of the switches to change the channel assignments for the sticks. In other words, set it up so that when (for example) the D swtich is up, the transmitter uses:
Channel 1: Elevator
Channel 2: Ailerons
Channel 3: Rudder
Channel 4: Throttle
And then when I put the D switch down I get:
Channel 1: Elevator
Channel 2: Rudder
Channel 3: Ailerons
Channel 4: Throttle
In effect, switching the Rudder and Aileron channels.
Channel 1: Elevator
Channel 2: Ailerons
Channel 3: Rudder
Channel 4: Throttle
Channel 1: Elevator
Channel 2: Rudder
Channel 3: Ailerons
Channel 4: Throttle
Hi codepunk,
Unfortunatley, no, the 7C is not capable of this.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
Hi freeagedcool,
You can find this on our website at www.futaba-rc.com, just scroll to the bottom of the page and click on the "manuals" link.
Sincerely,
Krysta
Sincerely,
Krysta
