Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9Z WC2 Internal Memory
Old 03-05-2005 | 12:18 AM
Default 9Z WC2 Internal Memory
I need to know how to delete a model memory (internal) in the 9Z WC2, i don't have a campac.
tnx
Old 03-05-2005 | 08:47 AM
rc4flying's Avatar
My Feedback: (21)
Default RE: 9Z WC2 Internal Memory
Jay,
You want to go into the Model Menu and select "RST" the you want "ALL" on bottom right column and follow prompts. This will rest all of that chosen model's settings back to default settings. But you will have to go in and change the model name manually by selecting "MNA" and typing the new name you want. ( EX. ) MODEL 3
Old 03-05-2005 | 02:32 PM
Hi Thanks you for reply
I have already done that but still do not resolve my problem. The problem is that I want to copy (Data Transfer) from a friends 9Z to my 9Z and I don't have enough memory available to complete the transfer. I'm using 7 of 10 models and only 12 conditions in my 9Z
I want to delete a model that I'm not using anymore in my 9Z to make room for the model I want to transfer.
Old 03-05-2005 | 03:55 PM
rc4flying's Avatar
My Feedback: (21)
Jay,
Have you tried to copy right over the model you wish to delete ?? Also, you may know already, but press the RCV button in the data transfer before you press the Trans button on the Transmitter you are sending it from. Just a thought. I have had that happen, it just took several tries if I remember right.
Old 03-06-2005 | 07:42 AM
Hi
I find the cure.
I discover that my friends 9Z was on PPM and mine on PCM, changed the friends 9Z to PCM and was able to Transfer the model just fine.
