14MZ model creation error
CA
I have 3 models in memory. #1 is a heli, #2 and #3 are both airplanes. If I select Model 3, an airplane. Then try to create a new glider, I don't get the correct wing selection page. I end up with the airplane wing selection page. If I then select my heli and create a new glider, then I get the full range of wing templates.
Regards, Guy
Regards, Guy
CA
I read your FAQ today and realized that the problem is that my heli is a G3 rx and my airplane model is PPM. That is why the wings didn't show up.
But there is still a bug. If there are things dependant on the type of rx you have in your aircraft, then that should be chosen earlier. When a new model is being created it should go to the freq. page first instead of assuming that the new model is going to be the same rx type as the current model (which is what it is doing now).
Regards, Guy
Regards, Guy
