Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Split elev in GLID2 on a 9C
Old 04-07-2005 | 01:38 AM
Default Split elev in GLID2 on a 9C
Hi
I am trying to set up a "fullhouse" glider/sailplane on my 9CH for use on Aerofly Pro before venturing into such a big glider. The model is a Ventus 2C with 4 servo wing Ail L/R, Flaps L/R and Elev L/R, Rudder, Airbrake, Tow hook.
I have gone through the manual to set up and I am close but I cannot get Channel 8 to link to the elevator and move with the elevator stick. It moves with Knob B.
I would apreciate your help on this.
Thanks Jeff
Old 04-12-2005 | 10:40 AM
Bax
Default RE: Split elev in GLID2 on a 9C
You'll need to use a free mixer. Set up the elevator as the master and channel 8 as slave. Link ON, trim ON. Set the percentages to the numbers needed to get the direction and travel as needed.
To turn off the knob, go to the Aux-Ch screen in the basic menu and set the channel 8 setting to Null. That turns it off.
