P mixes won't work with dual elevator servos on 9C??
My Feedback: (16)
NJ
I set up dual elevator servos on my 9C using the Ailevator funtion and setting up a mix between ch 2 and ch 7 with Link On. In both cases the elevators work fine but.... I have another mix that links rudder to elevator to correct for pulling during knife edge flight. In both cases only one half of the elevator moves in response to the rudder [:@]
The only solution I could find was to duplicate the rudder elevator mix once for channel 4 to 2 and once for channel 4 to 8. Now both elevator halves move in response to the rudder.
Am I missing something??? Is there an easier way???
George
George
RE: P mixes won't work with dual elevator servos on 9C??
Hi George,
The easiest way to do this would be to follow the FAQ for this at:
http://www.futaba-rc.com/faq/faq-8u-q586.html
Then do a single mix from Elevator as Master, Rudder as Slave, Link Off, Trim on, switch Null and the set your rates as you desire for the amount of rudder action linked to Elevator throw.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
