MORE 7 CAP PROBLEMS
My Feedback: (9)
Dear krysta.
I´m Experiencing again problems with my transmitter.
For some extrange reason sudenly the the ruder chanel is working as an slave of the throtle chanel. In all the models programed, and available.
I tried reseting the model configuration, and the same problem persist.
I cheked all the programed mixes and they are inactive( status: INH)
I cheked parameters so they are ACRO, PPM. ( ok)
The only solution I found is programing a Mix ( Throtle master and Ruder as slave) to correct the unwanted deflection of the rudder when you throtle up or down.
What could be the problem?
thanks
Juan Vadillo
thanks
Juan Vadillo
