Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
servo using standard with digital
Old 06-13-2005 | 05:51 PM
My Feedback: (12)
Default servo using standard with digital
is there a problem with mixing servos..ie; digital with standards using a futaba system
Old 06-14-2005 | 07:43 AM
BarracudaHockey's Avatar
Default RE: servo using standard with digital
No, the reciever dosn't know what kind of servo is hooked to it.
Old 06-16-2005 | 04:17 PM
Bax
You can "mix and match" any Futaba servo with any other Futaba servo on your Futaba receiver. The only consideration would be to make sure your battery pack is of sufficient capacity to handle the current-drain of the servos you choose. For example, you can use Giant-Scale Digital servos on your elevators and ailerons, non-digital servos on your flaps, and a micro-non-digital servo on your throttle and retract gear air valve. The receiver doesn't "care", nor do the servos "know" what other kinds are connected.
