Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9CAP HELP
Old 06-24-2005 | 07:36 PM
Default 9CAP HELP
Hi Guys,
I just purchased a 9CAP and cannot get the throttle setup. It seems that I do not have any trim adjustment using the trom button on the front of the radio. I f I set the servo at center I get a little movement with the trim tab, but if throttle servo is driven full open or closed I get no movement using the trim tab.
What am I doing wrong?
Old 06-24-2005 | 07:54 PM
D Bronk's Avatar
Default RE: 9CAP HELP
Hello TSUPPA. Go in your manual and look for your end point settings sounds like they are out of the ball park.DO you have one(MANUAL)....FLY for NOW!!!! DAVE B.
Old 06-24-2005 | 08:03 PM
Hey Dave,
I checked that and they are both at 100%
I even tried inputting another blank model and it has the same prob.
Any ideas?
Old 06-24-2005 | 08:36 PM
D Bronk's Avatar
you know what else these radios have programable MIXES,quite possibly a bad(goofy) mix program check that over too.
Old 06-24-2005 | 09:02 PM
Nope, Checked that all mixes are inhibited
Old 06-24-2005 | 10:54 PM
Dan767's Avatar
My Feedback: (19)
Check to see that the throttle trim isn't set to the top end. This happens when the "ATL" function is set to "Off". Open the Basic menu, then the Parameter submenu. Go to ATL and change the setting from what it cuurently is. Hope this helps
