Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9CAPS throttle timer trigger
Old 06-29-2005 | 08:23 AM
Default 9CAPS throttle timer trigger
I just got a new 9CAPS, and I can't figure out how to get the throttle to trigger a timer. I can not get the POS point to change. It's just always on NULL.
Kerry
Old 06-29-2005 | 09:22 AM
Default RE: 9CAPS throttle timer trigger
Hi kerrydel,
Have you moved the throttle stick to the position you want it in and then press and hold the dial until you hear a beep?
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Old 06-29-2005 | 11:19 PM
ORIGINAL: Krysta
The HOLD was the key. Thanks.
Kerry
