BATTERY VOLTAGE IN 9C
IN
My 9c only reads 10.8 v when left overnight or longer on its own charger is this a problem?
Also what is the best easiest way to prog an imac set up 4 aileron servos y'ed on two channels to work as flapperons in 3d
Kindest regards Ian
Kindest regards Ian
10.8 V is fine. The battery pack is rated at a nominal 9.6V. You can safely operate down to about 9.0-9.2V.
For your airplane, just consider it a two servo model. Left and right ailerons. Turn on flaperon function, turn on flap trim. Adjust the percentages to suit.
The big thing is that you have two servos per aileron. You must make absolutely sure that the servos/pushrods/control horn geometry of the servos on the same surface is correct or the servos will fight each other slightly, and rapidly wear out gears. That's what the Futaba MSA-10 Servo Synchronizer was designed for. It replaces the "Y" harness for each side so that the travel, movement, and centering of each servo on the same channel can be perfectly aligned.
