Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Ch. 5 Switch not working
Old 10-24-2002 | 09:28 PM
Default Ch. 5 Switch not working
I was helping a guy set up his heli with a 9C today. I could not get switch F to take the GY401 out of heading hold. The only difference between his radio and mine is he was using a PPM receiver.
It worked on the servo test, but not on the servo screen when I flipped the switch.
Is there something not so obvious that would hold that switch in one mode. I looked at every menu. Thanks
Old 10-24-2002 | 10:20 PM
HiV, Did you check the auxiliary channel screen to see where he has channel 5 assigned?
Old 10-24-2002 | 10:28 PM
Yep...it was assigned to switch F. When I flipped the switch and looked at the servo screen, the display barely moved as if something was restricting the movement. It moved only say 10%.
Old 10-24-2002 | 10:30 PM
Sorry, HV, without seeing it, it'd be tough to tell. Way low ATVs, odd mixing, a condition that you're kicking in and out of?
i would go into a blank model and start from scratch. does ch 5 move ok when nothing else is set up? if not, send the radio for service. If so, something is wrong with his other setup. start over.
Old 10-24-2002 | 11:02 PM
OK...Thanks. He is sending it in this winter, there was a blank line across the screen.
It was not the ATV. Checked that. No mixes present. No conditions used other than normal. Oh well, I will tell him to start over. He had another friend try to set it up and had it all messed up. I should have started with a clean model. Thanks for the input.!!!!!!
