Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
How to replace 9Z built in lithium battery
Old 08-28-2005 | 11:21 PM
Default How to replace 9Z built in lithium battery
Does anyone know how to replace 9z built in lithium battery, I have opened the back cover but did not find any objects look like a lithium battery.
Old 08-28-2005 | 11:23 PM
Default RE: How to replace 9Z built in lithium battery
pls send me pictures if you have
Old 08-29-2005 | 11:32 AM
Hi pentras,
We here at the Futaba Service Center cannot give you instructions or help in changing out your lithium batter. We can only suggest that you send this into our service center to have our technicians check this out for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
ORIGINAL: pentras
Old 08-29-2005 | 06:55 PM
I just replaced mine but that's not easy as there's a lot of cables to remove, together with some PCBs.
The lithium battery is located under you battery compartment and to remove it, you have to open pretty much everything. You want to take your time, work by steps and use different small cups to store the screws for each step. You then want to remove the board and unsolder the old battery using the correct tools for the job.
If you're not familiar with electronics, I would not recommend it. Send it to a repair shop.
Otherwise, I'll be in Hong-Kong on the 19th of September for a week! ;&gt
Old 08-29-2005 | 08:04 PM
my 9z was brought in Hong Kong, can I send it to Futaba Service Center USA for repair or else?
Old 08-30-2005 | 10:55 AM
Bax
If you're in Hong Kong, there are service centers there. You can locate the distributors at:
http://www.futaba-rc.com/futdist.html
There are several in Hong Kong.
