9C Flaperons
OH
I am running Ch6 for my left aileron.
I have decidec I wanted to try flaperons, coupled to the elevator, like a control line model.
I disabled the "differential" type and activated the "flaperon" type.
When I did the left aileron will not move with the aileron stick but it only moves with the ch6 dial.
What am I doing wrong?
I checked the FAQ's on the Futaba website.
Question 7 under airplane setup came close but didn't help.
Thanks!
John L. Konneker
Thanks!
John L. Konneker
If you're using the preset mixers, you won't be able to use more than one of them to affect a single function. If you're using flaperon mixer, then the elevator -> flap mixer won't automatically link to the aileron channel. It will only affect the flap channel.
If you want flaperons and elevator -> flap mixing, you'll have to use the pmix's.
For flaperons, you'll need 2 pmix's: aileron->flap, and flap->aileron. Link ON, Trim ON.
To get the elevators to activate the flaperons like a control line model, you'll need to use another 2 mixes: elevator->aileron, elevator-> flap. Link ON, Trim ON.
