Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9VAP Module
Old 09-21-2005 | 08:34 AM
jlkonn's Avatar
Default 9VAP Module
Will the transmitter module from my old 9VAP work in my 9CAP transmitter?
Thanks!
JLK
Old 09-23-2005 | 04:54 PM
Bax
Default RE: 9VAP Module
It's not intended to. You need to use a TP module in the 9C. The 9V uses the TK module.
Old 09-23-2005 | 05:01 PM
jlkonn's Avatar
Mr Baxter,
Thanks!
I thought if I couldn't sell the 9VAP transmitter then I could at least salvage the module from it to use in the 9C on a different frequency.
But...guess not
Thanks again!
JLK
Old 09-26-2005 | 10:28 AM
My Feedback: (12)
ORIGINAL: Bax
Bax,
That is not what your website says. Here is a copy and paste:
"Why are there different modules for the 9Z and the 8U? Can I use my 9Z module in my 8?
The TK (NOT TK-FSS) module, which is designed specifically for the 9V and 9Z models, is also safe as a replacement for the TP module. The TP module, which is used in the 5U, 7U and 8U radios, may NOT be used in the 9 channel radios in place of the TK module.
The TK-FSS module is a synthesized system module compatible only with the 9Z."
The link is: http://www.futabarc.com/faq/product-faq.html#q19
Which is it?
Jon Lowe
Old 09-27-2005 | 09:50 AM
Bax
We didn't realize that FAQ was still there. The module for the 9V/9Z really isn't recommended to be used outside of those transmitters. Maybe once, but it's not a good match.
Old 09-27-2005 | 11:09 AM
jlkonn's Avatar
Mr Baxter,
Will I damage my 9C if I try it?
If not then if I get a good range check shouldn't I be safe?
Thanks!
JLK
Old 09-27-2005 | 01:49 PM
My Feedback: (12)
ORIGINAL: Bax
Bax,
Page 10 of the online users manual for the 9C also says that the TK modules may be used. No limitations/restrictions are indicated.
http://www.futaba-rc.com/manuals/9c-manual-v1_2.pdf
This is also consistent with the FAQ referenced earlier, and this answer from Krysta on RCU:
http://www.rcuniverse.com/forum/m_14...tm.htm#1455509
Note that TP modules CANNOT be used in 9V or 9Z transmitters, but that TK modules can be used in 9C's, acccording to the references.
Jon Lowe
Old 09-27-2005 | 11:31 PM
My Feedback: (14)
A little off the subject of this thread but on the subject of the 9C I have a question for Bax. I want to back up the model memory of the 9C and campac. Is there a way to do that? I have heard of a cable you plug the campac into and then to a computer along with some software that is free somewhere. If so, that would only back up the campac memory but not the models resident in the 9C itself. Questions, questions??????
