9chp
I have been told that i can have stiffer springs put on my transmitter ( i have them adjusted as stiff as allowable) but that I would have to send it in to be done.
a. where do i send it?
b. How much will it cost to have the stiffer springs put on?
c. How long will it take?
I also have some receivers and servos that were in crashes, that I would like to have checked. The same questions above apply.
Your help is greatly appreciated.
Wayne Lovett
Wayne Lovett
Hi Wayne,
The springs themselves would cost less than a dollar, labor for putting them on would be around $15.00. Our turn around time right now is approximately 3 business days.
As for the check outs on the receivers and servos, you can find our address, a printable Return for Service Form and Flat Rate fees for service at: http://www.hobbyservices.com/futaba-rates.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
